[SOLD] champion radiator cc2374
1972DusterPaul
Northville (Southeast) Michigan
$120 PLUS shipping
I bought this before the correct radiator was available for my Duster.
I added a couple "slots" on the mounting tabs to raise it up to clear my Mopar Performance fan (that may not have been needed with a stock fan???).
There is nothing wrong with it, other than you can't use a factory shroud with it. I have a young son so I wanted to add a shroud for safety, and that is the reason for me swapping it out.
It cooled my mildly built 340 great for just under 500 miles.
Like most Champion radiators it has a bit of a "twist" to it. I corrected it by adding a couple washers (for spacers) on opposite corners. You might be able just to tighten it down to flatten it out, but I didn't want to try.
Anyways details from the Champion website:
Champion All Aluminum Radiator
3-Row Core
Cools up to 550hp
Radiator Dimensions:
Total: 20" tall (21" with cap) x 25.75" wide (with brackets)
Core: 15.88" tall x 21.5" wide x 2.5" thick
Inlet: 1.5" driver side
Outlet: 1.75" Pass
Tanks: 2.75" thick
Tubes: 0.63" thick
Bracket Mounted
(No OEM Shroud Support)
Radiator Cap included
Transmission Cooler included
Custom Aluminum Shroud available (sold separately)
Note: This radiator is shorter than OEM
(To fit Multiple Mopar cars)
Thanks for looking,
Paul
