Changing '69 Dart SBP to BBP
Monk67
St Louis MO
Looking for information......parts list/suggestion.......on changing SBP to BBP on '69 Dart, drum brakes all around.
Been looking on internet but would like someone who's done this for some guidance on where to source parts.......and parts needed.
Thanks in advance
Dr diff is easiest, if you're not concerned about originality.
Swapped all mine to 1974 Dart parts.
Front Disc's.
Control arm w larger ball joint.
Axles, and went from 9" to 10" drums in rear.
what is your reasoning for doing this?
it seems like a lot of work for a small return
(and i think the answer to that question will help narrow down how you want to do the front)
Thanks.......Great question and I probably should have mentioned that up front.........basically looking at more wheel options for the car.
in that case, i would do what Doug said, find a BBP rear end that matches yours (if you switch from an 7.25 to and 8.25 you would need to shorten your drive shaft)
the for the front, you can use a set of spindles from a B body (i believe) and use their brakes, or use a set of 72-up A body discs (also from the spindle out)
