64ragtop
The ragtop's been running what appears to be a stock '64 engine/front lights harness, modified for electronic ignition. Due to bulkhead connector failure, I'll be replacing it and have questions.
The car now has one field terminal grounded on a later model alternator, a stock appearing voltage regulator with electronic guts, single ballast and four pin MOPAR orange box ECU. I could replicate this by cutting the harness on hand and adding the electronic ignition harness, thus losing the warranty.
Or I can get another harness already modified for electronic ignition. That wants both fields from my alternator, the 1970-up (flat pack) V.R., the dual ballast, and five pin E.C.U. connection. I suppose I'd also need a new 5 pin E.C.U. box. This method will require purchase of four parts and a bit of re-arranging my underhood real estate.
I've looked at wiring diagrams 'till my eyes glazed over and the old electronic tech in me understands how the two different ballast/E.C.U. setups work. What I don't understand is the purpose of the constant 12 volts through the five ohm resistor side of the dual ballast to pin three (green w/trace wire). Does that voltage that is applied in both "start" & "run" key positions make an improvement in the performance or durability of the system.
Any help is much appreciated, as always.
