chasb- strg. question
jerry's demon
Active Member
in regard to" steer & gear" co., i am real happy with my new p.s. box. only
have driven about 50 mi since install, but have good road feel, not like orig.
recommend them highly. sorry i could not respond sooner.
jerry
jerry
Thanks
My mail box was a full as well.
What motor do you have? I'm not sure I can fit the booster unit in my engine compartment with that 440 stuffed in there.
Chas
have 340 small block. i have man brakes now, so booster will be no problem for me.
you may have to offset your booster if you elect to use one. remember, you need
around 19# vacumn to use booster. if you go to p.s., ck out your headers for clearance around p.s. gearbox. good luck.
Thanks
Not sure if there is much room down there.
I may have to stay with manual discs which will still be better than drums
Chas
