i ve spent a lot of money in the past on fasteners. i m sure a lot of other people have too. i ve been using muratic acid to clean metal for a long time. i also a lot to clean tools from work. some will argue about this method, b/c they say it removes metal, and b/c of the flash rust. usually u acid dip something. it looks beautiful, u rinse it, and when it dries,,,,,it instantly starts to rust. PROBLEM; u need to neutralize the acid, and coat it with something to keep it from rusting. i soak the part in acid til the rust is gone, then soak it in soapy water with baking soda in it. then i soak it in a different container with a mix of water and "RUST-BAN". after that. just dry it off and thats it.
this method works well for me.
as far as the fear of removing metal? i put a paper thin set of washers in the acid with some other parts for hrs. and hrs. still got em... they re just shiny and bright now. i like this process because i don t have to babysit it. i can dunk stuff, and walk away. normally it only takes less than a 1/2 hr. to clean rusty bolts and stuff. then u can paint em. here s what i use:
1. 3 plastic coffee containers with lids
2. first container has muratic acid(not diluted)-(just deep enough to submerge parts)
3. second has mix of dish soap, baking soda, and water
4. third has 20-1 mix of water and RUST-BAN.
i picked the rust ban up from my local powerwasher company. it just keeps the metal from rusting, i ve used this for years. it s the magic ingredient for keeping the metal from flash rusting.
I RECOMMEND DOING THIS WHOLE PROCESS OUTSIDE OR SOME PLACE WELL VENTILATED. THE ACID FUMES ARE HORRIBLE. I D WEAR A MASK, GLOVES, GLASSES. THE FUMES CAN ALSO CAUSE BARE METAL IN THE SURROUNDING AREA TO FLASH RUST. SO BE CAREFUL. it does work great though.
