Cheaper alternative elec. fuel pump?
JoeDust451
I'm looking at these carter elec. pumps that freeflow 100 gph, internally regulated between 6-8 psi, I never heard anything bad about them & hear they are quiter then the holleys, I was going to get a mech. carter HV, but alittle nervous about the diaphram blowing out & pumping gas in the oil. Is anyone useing one of these?
http://www.jegs.com/i/Carter/180/P4600HP/10002/-1?parentProductId=748050
Basically, because I said so. LMAO Honestly, I've replaced a good many of that type fuelpump you posted.....not necessarily the Carter brand, but that particular style pump. they don't flow as well as the one I posted. That summit pump s actually made by holley. I can't remember which one it is.....it's either the red or blue pump.
Thanks, I was going to get the Aeromotive 11203 if i spend that much.
do yourself a favor and flush out your gas tank/replace the strainer and filter before you install any electric fuel pump. make sure the pump is isolated using rubber bushings to help reduce noise.
