equium
70 Plymouth Valiant, 318:
So I've been fighting an oil leak that is coming from the rear of the intake. This is the second time I've reinstalled this intake and I was pretty sure I fixed the leak in the beginning. Since then, I've replaced the valve covers and installed new breathers. The leak came back eventually. I've replaced the oil pressure switch and used teflon tape. I just installed a new skip white distributor with new O ring. My theory is that with the new valve covers and the cheap spectre performance breathers, I may have caused excessive pressure and blown out the silicon on the intake. You'll see in the photo I'm using a single PCV and two breathers.
Let me know if this is proper or if I'm doing it wrong.
thanks.
Danny
thanks.
Danny
