straightlinespeed
Sometimes I pretend to be normal
Im replacing the bushing in my rear suspension. I have the FSM, but Im questioning the torque specs for the rear shackles and mount. The rear spring mount says 30 ft. lbs., I was expecting more, but that is reasonable. The one I question is the shackles nuts, the FSM say 45 ft. lbs. for non 7-1/4" rear ends, I have a 8-3/4. That seems like a awful lot of torque on that small stud.
Should i just snug them up good and tight or is there a recommended spec I should follow. I dont want to snap the stud off.
