cherokee rear disk question
e50095
I fiound a 95 Grand Cherokee in my local U-pull it. A couple questions if you can help me out.
1. I understand they have either a Dana 35 or Dana 44 in them, and that both are good to go for the 8.25 swap, a bolt on mission, correct?
2. Will I need to pull the Jeep's rear end cover and remove the axles to get the caliper brackets off? If not, that sure will make life easier.
thanks guys...
Kendall in Pa.
I believe you'll have to pull the cover to remove the c clips. I'm in the process of installing GC rear discs to a 74 A Body 8.25. Other than enlarging the axle hole in the caliper adapter/dust shield, it's a pretty much bolt-on.
