Just a thought, and needs to be critiqued by engine builders, so here goes. If you are a whisker too long on pushrods, say .040 or so, could a washer be put under the stud to move stock rockers up a touch? There must be some thin washers out there that would do the job, as going too thick could be a problem. Or a guy could do what I did on my Jesel rocker bars on my BB, make shims out of brass stock from the hardware store. If the shims were made of steel, they could be oversized enough around the edges, to bend them over for locating tabs.
To keep from destroying the stock I worked on, I had to pin the brass stock between a couple of pieces of plywood so the bit wouldn't tear the stock up.
Come to think of it, since these rockers are paired, it would be easy to pull a pair and see how things are holding up.
I put brass shims under my Jesel rocker bars on my BB race motor, huge roller springs, 7500 rpm, 200 passes no problems.
