Mopar to ya
I made a push in breather with a pcv for my Ramcharger, but ended up making a smaller one out of a chrome oil cap. This is a chrome breather I drilled a hole into, then added a rubber grommet and pcv valve. I pulled out the inner material. It comes with a 1 1/4" grommet for the valve cover opening. This is a push in style, but it will likely work in a twist in style as the grommet will seal the opening. Can't guarantee that, but I held it up to my Dart with the twist in and I think it will seal. This was installed on my Ramcharger, started once, run for 1 minute and removed. It is basically new. $10 plus shipping from North Branch, MN.
