I can`t tell you about that particular hydraulic clutch but I did install the Keisler hyd. clutch in my Barracuda. I mounted the master cylinder to the lower drivers side bolt of my brakes master cylinder. I had to remove the overhead spring on the clutch pedal. The slave cylinder mounts by sandwiching a plate on the firewall side that mates with a corresponding plate that`s machined into the slave cylinder. The slave attaches to the pedal with a Heim joint. The throw out bearing mounts on the input shaft as any mechanical type TO bearing does and the hydraulic hose is fed through a plate that covers the opening in the bellhousing. Fill it, bleed it, and away you go. It definitely has a different feel than a mechanical clutch does, but you get used to it.
