Anyone know if the cigarette lighter receptacle is hot even if the car is turned off? I'd check my Valiant or Barracuda (both Darts under construction) except neither has a battery.
I'll check when I get home...BTW thanks again for the NSS.
Aloha Mike
Yes it is hot all the time.
No problem - if it doesn't work, let me know - got several more.
65dartman~BTW if I read the switch stud with an Ohmeter...should it read a short to the switch housing when the switch is depressed? I want to test it before I install it.
Mahalo 65dartman!
sorry for jackin your thread!
Aloha
Dang! Thats what I thought too...well the one 65Dartman sent, reads an open. Bummer. I'll see if he has any others.DFMSMN- yes a NSS switch should read a short to the housing when the switch is depressed.
