Classic Auto Air Fit with BB Stroker Motor ?
DonnieLawson
68 Barracuda
Middletown Ohio
Has anyone used the Classic Auto" Perfect fit" kit it their A body?
I have a 68 Cuda with a 505 RB engine. It also has fabbed Aluminum valve covers .
My concern is how much clearance there will be between the passenger valve cover and the hoses where they come out of the fire wall where the heater blower was .
My cam is a solid lifter cam and the valve covers will need to come off from time to time.
And if anyone has this system , how do you like it . I normally wouldn't put air on one , but the older I get , The more I like the cool AC on the hot muggy Ohio summer days .
Also, does anyone with pics of a installed unit with a big block in the A body ?
Donnie
don't have a big block, but have the Classic air system
The hose connection coming out of the blower hole is smaller than the blower, take a good look at the stock location of blower to engine should give you an idea of clearance.
Since the hoses actually attach to a bulkhead, you could get custom hoses made to turn 90 deg, at firewall
I can take some pictures if you need them.
Hope like hell they have improved the wiring diagram, there are 2 connectors that are exactly the same and cannot be reversed, mine was trial and error, or make that error 1st. Had to make a piece for the heater control that wasn't in my kit but not a problem to make.
I also made the bracket to mount the heater control valve to inner fender, didn't like the idea of it just being supported by the hose.
