WARLOCKII
I have an assortment of parts that I would like to sell as a package deal. Here goes:
1-71 383 short block (cast crank, needs rebuilt) it has a piece broken off where the trans bolts up. can see in picture.
1- 66 383 short block (steel crank, needs rebuilt)
1 pr of 516 heads (need rebuilt)
1- 383 distributor #3690431
1- 187 oil pan (has had 2 holes repaired, bottom of pan is rough)
Big block timing chain cover, chain and gears, water pump housing, valve covers, rockers shafts, 2 sets of push rods.
1- 727 trans. pan
1- pair of upper control arms, spindles with 9" drums and F&R bumperetts from a 72 Swinger /6
I also have parts from a 76 Dart 2dr 318/904
R & L doors glass, rear flip out windows and the rear window. gas pedal, fuel line (pump to carb), trans. inspection cover, hood hinges, arm rest w/ashtray's and water pump pulley.
8 1/4 rear end (2.45 gears, non posi, no backing plates) and a pair of rear springs (good for a roller).
These parts are not show quality but would work for a daily driver. I would prefer local pick up as the engines and rear would be to hard and expensive to ship. The parts are located in Urbandale, Ia. I 'm asking $200 for everything listed. PM me with any questions. I work nights so it may take me a day to get back to you.
Thanks for looking :glasses7: Jeff
1- 727 trans. pan
