chooch
cleaning out the garage & the extras need to go!!!
-fresh rebuilt with brewer parts18 spline hemi 4 speed case date april of 1972 with B/E tail housing $1500
-fresh rebuilt with brewer parts 23 spline 4 speed case date c1965 B/E tail housing $1000
-new mopar perf hemi cross ram never used or mounted $600
-mopar b/rb purple cam new p4529318 .533 lift $125
-very rare edelbrock str 14-6 intake uncut or modified $700
-a12 air cleaner assembly with filter,base plate is a repop fiberglass piece $300
-D440 HP2 build date 10-11 & cast date 8-26-67 bare block with caps tanked & magged standard bore $700
-426 street wedge bare block with caps & heads no casting dates build date 3-21 tanked & magged standard bore $700
-E383 hp from a 68/69 cuda very rare A body engine with caps correct heads ,crank ,intake, water pump & the hard to find drivers side motor mount & early A body K frame.
Cast 9-26-67 / build date 8-21 tanked & magged standard bore $2k for everything
-A body 440 drivers side motor mount $150
-classic air complete a/c conversion including rebuilt heater box for 68-70 mopar b-body everything is new or like new. This set up is the only complete & easy to install unit on the market $1200
-B body adjustable steel strut rods $100
-B body aluminum strut rods $150
-sure grip with 3.23 gears $250
- sure grip no gears still has ring gear installed $150
- sure grip no gears $sold
-489 case 3.55 gears sure grip $sold
-edelbrock performer #1407 750cfm square flange, manual choke like new $175
-mopar B1 heads,valve covers, 2 intakes & b engine spacers all new or like new just been sitting a while $2500
-edelbrock torqer intake $75
- 68-69 b body dana never cut complete but taken apart 4:10 gear $1200
