earthmover
in the tire smoke
727 trans case..good case was used for my small block motor took all parts out and used in my big block trans..$50.00
kb107 pistons std boro 6good piston and 2 have chip in the bottom of the skirt..all are on the rods with rings little run time motor ate 2 camshafts so block was junked ....$150.00
com cam soild lifters used a few runs and took out and replaced cam and lifter..4 have surface rust but all was oil (rust on the bottom) $25.00
holley 950hp carb used on my 340 and worked great $350.00
big block heads 452 no valves $50.00
shiftnoid shifter set up used in good working cond. $125.00
727 trans blanket new never used but out of date red rci $100.00
w2 intake gasket set new mr. gasket brand 10.00
small bolt patt. axle fit abody rear $75.00
misc. parts valve cover,water pump,dist,and moroso plug wires,and some odd and ends $55.00 water pump worked when pulled ,dist. 1 is welded for locked out timimng,and I think 2 more dist,wires where on my small block but took them off and replaced them with some taylor,and some other small stuff..
big block alum valve covers 100.00 new never used
aluminum fuel cell new never used $150.00
bg fuel pump 400 and filter and lines used but in good shape $200.00
will post pics here soon
all parts are + the ride and located in north Carolina 27816
:cheers:
:cheers:
