Aug 14, 2008 #1 orangecrush Well-Known Member Joined Aug 8, 2008 Messages 147 Reaction score 0 Flat tops are .035 above deck - will check piston to valve clearance this week. Thanks Goldmember.
Aug 14, 2008 #2 orangecrush Well-Known Member Joined Aug 8, 2008 Messages 147 Reaction score 0 Couple more - old vs new
Aug 15, 2008 #3 M moper Well-Known Member Joined Dec 27, 2004 Messages 15,912 Reaction score 2,540 Location eastern CT You're fine in terms of clearance. You need to add in the head gasket thickness, and remember the valve relifes go under the valve... But the heads look terrible if you are looking for any performance.
