[WANTED] Clutch/Brake pedal assembly
dustertogo
Brandon, MS
Looking for a good clutch/brake pedal assembly for a 73 Duster 340. Must be the "heavy duty" assembly that uses needle bearings for the clutch pedal instead of the plastic bushings.
If you cannot find the heavy duty setup ValiantOne was making some nice bronse bushings to replace the plastic bushing setup. Not sure if he is still doing this. These greased up will work just as well.
