Clutch fork help
66340SEDAN
FABO Member #3649
Minnesota
Is the clutch fork the same between the early 63-66 a-body cars and the 67-up? Thanks! Keith
I guess you`re referring to small block V-8 cars. From what I remember is the later model (68`s and up) are a little longer. I haven`t dealt with small block manual stuff for a while so I hope someone else will chime in here.
The length of the clutch fork on my 65 Cuda, is 12 5/8's. This is a factory 4 sp car. This is also the exact length of spare one I have, and I believe it was from a 73 318 Duster but not sure. (I have a box of spare trans stuff and it is just all thrown in, and of course I didn't label anything!)
I know my 66 fork is much shorter than the one I have for my upgraded 10.5" bellhousing.
