[Found!] clutch pedal return spring
searcher1990
Oregon
Looking for a clutch pedal return spring and the little cross hooks it hooks to on pedal mount bracket for early A body. Cant find mine after a year apart. I am located Oregon 97051. let me know cost plus shipping to my zip and thanks for any or all help.
What type clutch do you plan on running? If you run a diaphragm style, you actually do not need the clutch spring. It is called the over center spring.
I will have to check on this. I was going to get a hays street/strip 10 1/2" as I am going from 273-340. Already got the bellhousing, etc. thanks for the info!
