[SOLD] Coarse spline, 8 3/4 pinion yoke using the 7290 U-Joint
physixx
Edison, NJ
I have for sale a 10 spline, 8 ¾ pinion yoke that uses the larger 7290 series U-joint. The yoke is in excellent shape and was only used to set the pinion depth on a couple of center sections. It never saw the street or track. The number cast into the underside of one of the U-joint saddles is 2643008. Also included are the pinion nuts and washers for either the 742 case or the 489 case. The U-joint straps and bolts are also included. I would like to get $50 plus shipping for everything.
Ken
Edison, NJ
