I am finishing up the refresh/rebuild of my MOPAR 440/512 engine.
I am also trying to finish up my Coil Near Plug conversion.
This morning I drilled and tapped a 1/4 x 20 hole in the rear lower corner of each head.
These are the attaching points (for lack of a better term) for a bridging harness to tie each head and the XIM Block Ground together. The center terminal of the bridging harness and the block ground terminal will be secured together under the rear center valley pan 1/4 x 20 stainless button head bolt.
I read somewhere that the heads and block ground should be connected together at a common point.
Not sure if that is indeed the case.
Right side head Drilled and Tapped for 1/4 x20 Stainless Button head bolt
"Bridging Harness"
Bridging Harness installed as well as Crank Sensor, Cam Position Sensor and Temperature Sensor Harness.
Herb aka "Dart67"
"Bridging Harness"
Herb aka "Dart67"
