I am in the process of finishing up my wiring and I have swapped from an msd blaster to a accel racing coil. I am using a 73 dart wiring harness and chrome box. On my new coil instead of the normal + - it has batt and dist listed for the terminal lugs. I am assuming that the batt is the same as + and the dist is the same as -? Am I correct? Also my tach wire goes to the - side also correct?
