[WANTED] Column nuts at firewall
John Collins
Los Angeles
I’ve looked around and can’t seem to find to find them for sale on line. I’m not certain as to what they’re officially called and that could be the problem. Lol.
I can't think of one nut that hold the column to anything, bolts yes, nots no.
Alan
The nuts insert into a small cutout in the firewall and you bolt through the 3 bolt holes in the column bracket that secures the column to the firewall… From the inside, through the nut and into the firewall. The previous owner replaced one with a fender bolt, washer and nut. It works fine, but it’s a little wonky.
I was able to get a couple ok pics.
Kinda like a caged nut.
Wonder if you could use a nutsert.
