[WANTED] Column shift steering column
Scampin
Rating - 0%
0   0   0
Looking for a good condition 71 (or any year that looks correct) Duster steering column for manual steering and column shift auto. Complete but do not need the steering wheel. Should be fairly common?
Thanks!
As a whole column, '70-73 will work. There are some individual part differences and appearance differences though. For instance, the '70-1 ignition locks don't interchange with the '72-3 ones, so, you won't be able swap them if you want to keep your ignition lock. You could have the later cylinder re-pinned to your key though, or, just get the key with the later column and have the door cylinders re-pinned to match, or, use two keys.
