I just wanted to clarify everything in one thread:
'71 Demon 904/column auto
I want to use a stock auto floor shift without console and with my bench seat. I don't need the correct shift knob or anything, and I would simply use one of the aftermarket smaller consoles that Year One sells or something similar.
So this is what I think I will need, tell me if I'm right:
1. auto floor shifter
2. auto floor shift linkage
3. dust boot and grommet that attaches to the floor
4. either a 3-wire neutral safety switch, or wires to extend the column wires
Now here are my questions:
1. Assuming I unhook the trans shifting mechanism from the column at the transmission, and install the floor shift mechanism, it should be a simple swap?
2. Where exactly am I going to be "extending" wires to, if I have the 1-wire neutral safety switch? Would it be transmission to shifter, or column to transmission, or column to shifter? I don't quite get this one.
Thanks in advance
Thanks in advance
