michael_X
Active Member
Comp 995-16 springs. I got these as part of a package deal and won't be using them. They've been sitting for a while and a few have small areas of surface rust. The pic is one of the worst ones in the bunch, for reference you can see the spot on the top of the outer. Will probably some clean with a squirt of evaporust or a few seconds with a wire brush.
These are Comps recommended spring for higher lift flat hydraulic cams and some hydraulic rollers in small blocks according to my old catalog. Summit sells these for around $100. Buy these for $60 - Shipped in the US.
