[SOLD] Comp Cams dual valve springs and titanium retainers
Rocket
CT
I have a lightly used set of 16 Comp Cams 928-16 dual valve springs and Comp Cams titanium 10 degree retainers. These were lightly used fro ~ 600 street miles. I ended up going with a different cam set up that required different springs.
Outside Diameter of Outer Spring (in): 1.550 in.
Coil Bind Height (in): 1.160 in.
Spring Rate (lbs/in): 354 lbs./in.
Inside Diameter of Outer Spring (in): 1.150 in.
Inside Diameter of Inner Spring (in): 0.795 in.
732-16 Titanium retainers.
Uses 10 degree valve locks.
Summit price for these parts is $450. I will let them go for $270 shipped in the lower 48 states.
