[SOLD] Comp Cams springs & misc. race parts.
Locomotion
Florida
ALL PARTS NEW, NEVER USED
Comp Cams Beehive Springs # 26120-16
* 155 lbs @ 1.880"
* 377 lbs @ 1.280"
* Spring rate: 370 in/lbs
* Coil bind: 1.230"
- $165.00
Comp Cams Single Springs # 926-16
* 109 lbs @ 1.800"
* 317 lbs @ 1.300"
* Spring rate: 415 in/lbs
* Coil bind: 1.140"
- $65.00
Comp Cams 10* Steel Retainers # 740-16
(Fit # 926-40 springs listed above.)
* 1.437" diameter.
- $45.00
Comp Cams 7* 8mm Valve Locks # 623-16
* Machined hardened steel.
* Single groove bead lock.
(Have used with 5/16" Magnum style valves)
- $25.00 (1 set available)
Mopar Performance Race Coil # P3690560
* Requires 1/4 ohm ballast resistor.
$50.00
Russell Aluminum Inline Fuel Filter # 645140
Russell Replacement Filter Element # 651660
- Both $13.00 ***SALE PENDING***
Moroso Elec. Water Pump Hose Adapter # 63542
* 1" NPT x 1 1/2"
- $15.00
ALL PRICES INCLUDE SHIPPING WITHIN THE 48 STATES!
