RustyDusty
Rabid Cross-eyed Opossum!
I've been looking at the Comp Cam Thumpr series for my stock 360 magnum (I am willing to do a LOW cost build if it gets me into one of the slightly larger cams, I'm on a really really REALLY tight budget)... My main goal being a nice lobing choppy idle.
If I went with the hydraulic roller "Mother Thumpr" it says: needs 9:1 CR, 2500+ stall, intake, gears. Which intake, and gears would you go with? Also, the magnum runs at 8.9:1 CR, the Mother Thumpr says it needs 9:1, would stock CR be OK, or does that .1 make a big difference in the scheme of things?
They make it sound oh so simple, then further in the description it says:
Recommended Components:
Complete K-Kit K20-601-4
Cam & Lifter Kit CL-Kit CL20-601-4 [7]
Lifter Kit 822-16 / 867-16 [37]
Timing Set 2103 / 3103
Rocker Arms 1622-16 [23]
Push Rods 7958-16
Valve Springs 995-16 [2] / 26995 [2]
Steel Retainers 740-16 / 795-16
Valve Locks 626-16 [24]
Valve Seals 505-16 [2]
Camshaft Break-In Lube 159
Installation Notes (These notes apply to the above recommended components with the trailing installation note numbers)
Note Description
2 [2] Requires machining on cylinder heads.
7 [7] Stock springs cannot be used.
23 [23] Includes special shafts & spacers.
24 [24] Special 10º 4 Groove Lock. Single Groove use part #612-16.
37 [37] Adjustable valve train required.
How many of these components would you really change? Or would going with their "complete" kit be enough? (includes: • Camshaft • Valve Stem Seals• Lifters • Timing Chain Set• Valve Springs • Assembly Lube• Retainers • Decals• Valve Locks • Instructions)
Here are some links:
"Complete Kit"- http://www.compperformancegroupstor...re_Code=CC&Screen=PROD&Product_Code=K20-601-4
Mother Thumpr Cam- http://www.compperformancegroupstor...C&Product_Code=20-601-4&Category_Code=THMCRS2
Camshaft Specs- http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=638&sb=2
I know this is a bit scatter brained. I tried to get my questions across though. Thanks FABO!
Push Rods 7958-16
Note Description
