I am using comp pro magnum roller rockers they do have oiling holes that go through the socket adjusting screw, but only if they are lined up properly. ThanksWhat's the concern? The oil (well at least 99% of it) can't get out of the top of the pushrod because of the ball/socket at the rocker arm adjusting screw. You're not going to run out of oil pressure or anything.
