mini
Small Bore Long Stroke
So I am going to run a 282S Magnum can from Comp, and the springs they suggested are 995-16 - 115lb @ 1.700 and 336 @ 1.150 with
402lbs/in spring rate.
Now the heads I bought are finished with 994-16 which are 102 @ 1.700 and 303 @ 1.150 with a 367lbs/in springrate.
All valves currently have an installed height of 1.68" which would net me 109 seat and at .495 lift a 290lb open with the current springs (994)
My question is, would this suffice or does anyone recommend me go with the 995-16 springs.
