boosted
Life Needs Air
I have a mid to early 70's 318 2v motor with a/c comp still on it. Complete motor minus carb starter,alt and ps pump. Was running when pulled from car several years ago. Been stored under a cover and it is not locked up.
I also have a 318 aluminum 4v Edlebrock dual plane intake, Chrome air cleaner that will go with it.. Needs cleaning.
904 Auto with convertor and flax plate and lines. Again this was working when pulled from the car and was attached to the above 318.
8 3/4 A Body rearend Complete wheel to wheel.. yes it is a small bolt pattern rearend. 741 case has springs spring perch, shackles shock mounts brake lines and e brake lines all attached.
I do not want to separate and they must be picked up local.. I am In Midland GA.
Rearend is out of a 71 Duster.
$750 as a package deal..
Here is a pic of the rear end... I will post pics of the motor and trans later..
