heyitruns
Active Member
Hey FABO, I need some help and advice. The Dart is getting scary to drive on the freeway, steering is beyond sloppy, tires have more camber then i can explain and I'm going through front bearings and hubs faster then my wallet can support. I put this off for too long:angry7:, but it looks like its time for a complete front end rebuild, the original parts can't take it anymore.
Asked a few car guys I know (not Mopar guys) and they all say I should only be paying between $100-$200 for a kit. Now, I understand that 67's have a few quirks up front that make suspension parts a bit harder/more expensive to get. And on top of that anything for a Mopar always seems to cost a bit more then the same for a GM or Ford. But even then the cheapest kit I've found so far is this PST kit.
http://www.p-s-t.com/pc-3765-159-dodge-dart-1962-76.aspx
I'm good at drive train work but I don't know jack about suspension work (part of the reason I kept putting this off) and don't know if that's a good deal or a rip off. If you guys know of any good complete kits for less, let me know.
I'm also looking for a good sway bar kit and front disc kit. Found a couple front disc kits that bolt to my drum spindle, those any good or do i need a complete hardware swap out front?
I figure if I keep updating the dart with modern tech, I'll never need to buy a new car. Either way, I'm never selling her, so I might as well get her running right.
