Complete matching numbers 340 engine and Trans.
Michigan
Rating - 0%
0   0   0
The 340 enigine all orginal numbers matching. Early build for 72 , block casting is 71 for Cuda , Challenger, Roadrunner, Duster, Demon, Dart and Charger 1972.
It has power steering, fuel pump, pulleys, brackets, HP manifolds, heat shields, air cleaner, distributor, thermoquad carb all correct and date coded for 72 car. 727 trans automatic. Runs great when pulled very strong running motor, clean up drop in and drive, perfect for a numbers matching restoration
how is is it great for a numbers matching restoration if i do not have the car to go with it?????????????? lol
You can email me EDITED BY STAFF and I can send you pics.
NO EMAIL ADDRESSES PLEASE READ THE RULES BEFORE POSTING AGAIN
by reading other posts' of his, seems like he parted a 72 a-body!.
I actually bought a spare 70, 72, 73 along with alot of spare parts. I now need to clean out some room for some B-body resto.
Iphones cannot run flash.
email them from your phone then upload from your pc.
