Do you have a 64-66 Early A Body with the single speed wiper setup? Do you want or need the variable speed system? Then here’s a complete setup - variable wiper motor (and linkage) with correct terminals for variable speed, the variable speed wiper switch and the wiring to connect the two together plus the wiring for washer pump and backup lights. All the wiring is connected with the appropriate terminals at the wiper switch and marked to where it goes after the switch - 4 to the wiper motor, 2 wire harness for backup wires, 1 for the washer pump and 1 wire for power in to the wiper switch. The power wire will need a terminal to connect it to a power source when the key is on. This setup was removed from a running, driving early A Body I parted out.
I believe this conversion can be used on a 63 if the wiper motor bracket from a 64-66 is used to relocate the motor. There may be other modifications for the 63 that I’m not aware of.
$200 plus shipping from 22657 for everything you see in the pics. I will not separate the wiring from the switch and motor due to the special connectors at the wiper switch. I do have a couple other variable speed wiper switches if that’s all you need.
