i have a completely rebuilt 1971 318 small block block was sent out hot tanked and checked for cracks it is a stock bore the crank was also cleaned and check stock rods used stock pistons new rod ,cam and crank bearings all new seals heads were rebuilt and harden seats the cam is a mopar purpleshaft P4452757 lift 410/425 duration 248/256 overlap 32 degrees center line 110 it just a little more than a stock 340 cam
powercoated edelbrock duel plane intake
edelbrock 1406 carb (600 cfm with elec choke)
timing covered is powercoated
the motor is painted castblack
other than installing the rockers (wanted to keep valves closed to keep dirt and mosture out of inside of motor) this motor is ready to install and run
would like to do loc. pick up if not you have to set up shiooing and pick up it would be cost of shipping and building something to ship it in
