Compression fittings
Dartfreak75
Restore it, Dont part it!
Virginia
Who here uses them? I have used them on damn near every vehicle I've ever owned in the last 20 years and never ever had a issue or fail with them. I was reading an article today saying that you should never ever use them on brakes I have used them on brakes fuel lines etc and like I said never had a problem. What are you guys opinion?
Those fittings (The common brass "short nut" fittings) don't belong on automobiles PERIOD. I would not use them on either brake or fuel lines. There is no vibration resistance. Only exception is the smaller 1/8 oil pressure line which is inherently stronger because the line is smaller
There exists (used to) AIR BRAKE compression fittings, which used more robust ferrules and long nuts resembling flare nuts. These are/ were far superior. They were also used on the nylon brake tubing which is OD sized same as copper/ aluminum tube
Also notice the other type air brake fittings have an internal ferrule to support the ID of the tube from collapse because of the ferrule
tation-air-brake-fittings.jpg?width=232&name=compression-style-transportation-air-brake-fittings.jpg
There also exists STEEL compressin fittings which can be used on such things as power steering repairs. You cut off the old hose from the formed steel tube ends, crimp up a hydraulic hose with these type compression fittings, and then put them onto the steel tube ends
The common ones I was familiar with "back then" were for dual braid hydraulic hose, came in straight and 90
Wow I can't believe I'm the only one that uses them lol I always thought thats what they were made for.
Never use them for hydralic pressure, they will fail.
Oil pressure line line, ok because oil pressure is low pressure.
I just went through this with my Scamp. Snapped a brake line off and had to build a new one. Went to AutoZone and they loaned me a brake line flaring tool for free. Watched a couple of videos on YouTube and did a few practice flares and now I'm a pro, lol. It was actually one of the easier things I've done on the car and I really enjoyed crafting my own line. I also have a transmission line to fix also and when I'm done I can bring the tool back and it doesn't cost me a dime. But I think I'm gonna keep it! Here's one from Amazon that's about half the price as AutoZone's.
Auto Double Flaring Tool Kit Copper Aluminum Brake Line and Brass Tubing Tools 45 Degree Flares https://www.amazon.com/dp/B07T66MJG3/?tag=fabo03-20
Auto Double Flaring Tool Kit Copper Aluminum Brake Line and Brass Tubing Tools 45 Degree Flares Amazon.com: Auto Double Flaring Tool Kit Copper Aluminum Brake Line and Brass Tubing Tools 45 Degree Flares: Home Improvement
Yea I have one i just learned that you have to have double flares recently lol
Used for an emergency repair to get home from an off-road trip, but replaced line within day of getting home. Never safe for permanent repair.
AND NOW IT'S TIME FOR another annoying story from the old days
This is the Baldy road coming E to corner of Boyer, and in the time I am speaking, about 1976 ish, there was nothing to the right of Boyer, only scrub land, and if you look there are power lines running along, and there was a 1/2 lane dirt not-quite-an power company access road/ trail across Boyer from Baldy
So a then friend of mine had bought a ?67? ?66? Fairlane based Ranchero, and lived up "Baldy hill" a ways. One afternoon he related what had happened. He had bought the rig from a used dealer, and had not yet been under it. he was roaring down Baldy towards town, likely doing roughly twice the advertised 35mph speed limit, and applied the brakes to stop at Boyer. AND IT WAS JUST LIKE IN THE SONG...."sorta like steppin on a plumb"....and the Ranchero kept RIGHT ON GOIN across Boyer and bumping and banging down the "access road" until he finally got it stopped
WHY?? did this occur?
BECAUSE SOMEBODY had damaged the brake lines while pulling the transmission AND HAD SPLICED THEM back together using FUEL HOSE AND CLAMPS!!!!!!!!!!!!!!!
Man if someone is that dum they shouldn't be allowed to play with tools:wtf:
They're not made for high pressure. All that holds them together are the ferules that squeeze down around the lines. They are no way made for pressures exceeding 1000 PSI. I think brake pressures can exceed 3000 PSI in some instances. Just because you can, doesn't mean you should. If you want to connect lines together like that, the correct and SAFE way is with a flare union.
Those ferrules crush into the softer nylon or copper line. That was the day i stopped watching scotty kilmer. He repaired a brake line with a compression union.
The ones designed for steel line, aeroquip fittings or swage lock fittings i would consider. But im well versed in flaring brake lines so i go the cheaper route and make a proper flare.
Cheaper and safer. Two words rarely used in the same sentence.
I have redone many cars to remove the compression fittings installed by current or previous owner. One was on a 145+mph 3300 lb drag car. That was an eye opener with 8-10 compression fittings.
While they might work in most cases I always figured if something happened and the insurance company investigator found that the owner installed non-DOT brake parts there may negligence factored towards the owner. That might just be me being paranoid though. Wither way it's best to get a roll of CuNi and a good (Mastercool , etc) flaring tool to land everything with double flares.
