Compression Ratio and Boost Query
True. To a degree. My gen 3 hemi runs a 750 vacuum secondary with a tps and obviously distributiorless ignition. The only real advantage to go to fuel injection in my case, would be a swap over to a full outboard ECM like a Holly Terminator or similar. The benefit really isn’t in each electronic system being better. Its the ability to side-chain their input/output controls via other portions of the system. So, bolting on a Sniper system that can’t directly communicate with my MSD hemi 6 ignition would likely gain little advantage over a properly tuned carb outside of cold starts (I am running no choke) My point is: its never just the one component. Its the coupled system.
Beyond that, a carb is a much more elegant device than FI. Its reactive to affordance from the natural environment without external controls.(other than the throttle)
FI operates in a loop via binary external control, and if you count the 1000’s of silicon layer ‘transistors’ in the ECM as the electromechanical devices they truly are, it takes a thousand switches to operate one inductor/solenoid (fuel injector) thats about as inefficient as it gets systematically. It just gets ignored because most people view ECMs as a device and not a machine. If one is looking for systematic efficiency and repairability, a simple carb/points ignition is the way to go for gain vs. simplicity.
I am not saying FI isn’t the way to go in some applications. I just disagree that its ‘better’ overall in-and-of itself, and that ECM’s aren’t great unless they can utilize the input you need them too.
You'll get no argument from me about carburetors. I'm a carburetor guy and always have been and will be.
I am in the process of a 318 LA budget turbocharged build, and there seems to be a lot of common info suggesting limits of around 6psi boost for an 8.5:1 static compression engine.
I am aware of how timing events affect dynamic compression, and how all things being equal, these principals typically apply to forced induction as well. Anyhow.. I have tried most of the formulas and seen most of the common (and uncommon) charts/graphs.
My question (and what they don’t seems to explain) is this:
I had a 1191 4G63T DSM (Talon/Laser/Eclipse) that ran 15psi on 91 octane with zero signs of detonation. It had no tune, and was bone stock other than a 16G ported and clipped turbo upgrade, along with the cylinder head being decked .0015”. My guess is the decking pushed the factory 7.8:1 compression up to around 8:1. I understand the ECM was likely pulling timing and the heads were fairly efficient aluminum castings. However, that alone doesn’t explain why most ‘boost compression’ charts say that would be a ‘race gas’ engine.
Why can’t I run 15 psi (max) on a properly prepped/tuned 318 with 8.5:1 compression?
Furthermore: If a 6psi limit is true, try finding a turbocharger compressor that maps efficient at such low boost pressures and engine RPMS that meets the potential max CFM demands of a small V8.
Anyone have real world experience boosting a 318 that can weigh in?
Thanks,
I had a similar question about boost on pump gas. Here is what an engineer friend wrote up for me. It makes sense now. And trust @TT5.9mag advice. He has been helping me as well.
The simplified version is to use the ideal gas law PV=nRT to calculate your starting molar mass "n" by translating to (PV)/(RT) = n. P = Pressure, V = volume, R = gas constant, T = Temperature. Starting volume is cylinder displacement, starting pressure would be 90 kpa for naturally aspirated and 90 kPa + (boost pressure*0.90) for pressure charged. Estimating based on expected volumetric efficiency (90%). Temperature will be expected intake charge temperatures. 35C for N/A and 60C for pressure charged. You can then calculate the molar mass at bottom dead center / cylinder filling.
You know the compression ratio, so you know V1 (volume 1) and V2 (compressed volume 2). So you can use the equation (P1xV1)/V2 = P2. To find your compressed cylinder pressure. Once you have P2, you can again use PV=nRT to calculate your compressed T2 temperature. (P2 xV2)/(nxR) = T. Now that is purely compression based temperature changes, but for spark ignited engines, the ignition is before TDC and peak cylinder pressure will rise well above the static compression ratio pressure rise.
Which is where "late" ignition comes into play. Where you delay the ignition of a pressure charged engine to limit the maximum cylinder pressure (Pmax), which limits your maximum cylinder temperature, which directly impacts the propensity of knock. This is also done on naturally aspirated engines, but not to the same extent. For example, an engine with 10:1 CR runs a maximum cylinder pressure of around 60 Bar. The another with 8.5:1 CR runs nearly the identical maximum cylinder pressure of 60 Bar, but the angle of Pmax is much later in the cycle, the area under the curve is much larger, so it generates more power.
The lower 8.5CR reduces the initial cylinder pressure / temperature of compression, which limits the propensity of knock and allows late ignition. The trade off is a loss in thermal efficiency due to the loss in expansion ratio. Which requires additional air mass flow (more boost pressure) to make up the difference again. That trade-off shows up in brake specific fuel consumption which will be much higher.
You are saying what I was originally thinking. Obviously, just forcing air into a junkyard 318 and changing nothing is gonna end poorly. All things being equal, with proper controls, I think one could boost to the point where the internals, (mainly the crankshaft in this case) are the limitation.
I will check out that read. Thanks for the info. I have said for a long time that the best performance part one can buy is usually a book..
The crank in a 318 is the last piece of the puzzle to worry about. Even the cast cranks can survive at well over stock power. It’s the fragile cast pistons with very small ring gaps that get most people in trouble. They break ring lands pretty easily because the do NOT tolerate detonation at all. Rattle it even a little bit and they’ll let you know. Next will be the head gaskets, (I explained already how to help that) and then the rods bolts.
I plan to try some unorthodox (read dirt cheap) timing control and I plan to make it work, even though some say I cannot. That just makes me want to do it even more and I will.
I hope you post them when you do them.
Oh, I will. It's gonna be a bit though. I'll have the engine together hopefully this week if I feel as good as I do tonight. I've had a rough few days. The wait will be when I have to start buying stuff like the turbo and related items.
