In my 68 Dart GTS I had a set of the 2" tri gauge sets mounted under the dash below the ash tray that I could hardly see. Seems like every time I had to pull the console they were always in the way. Then I purchased a 2 5/8" set so I could see them better. I realized I won't be able to pull the console without removing the gauges so I built this mounting panel. It hooks under the lip on the driver's side of the console and has a lip to fit under the driver's side. I then will install 1 screw to hold it in place. Next step is to send it to Leanna"s for powder coating. Black I'm thinking
