Console mounting help
green440duster
Porter's Lake N.S. Canada
Does anyone have the dimesions for the 2 support brackets that weld to the floor for 70-76 abody? Also where does the bottom bracket (for the shaft that ties the shifter to the gear selector lever) bolt to looks like it should be the trans but it has two studs and I don't know where it should mount.
Thanks for the help
Jamie
