Jayman62
Hello,
I will be converting my 1966 Dart 225 slant 1 barrel intake to a super six intake. I had some questions.
I have read you need a gas pedal from an early model V8 a-body to replace the current rod style, these are somewhat hard to find, is there another option like a universal cable style someone has used with success.
Also there is are EGR valve holes, can i just makeup a blocking plate and gasket for those? Thoughts on gasket material?
I intend to get the Lokar cable for the kick down,
Thank you.
Thank you.
