I have a 1970 340 fresh build, I put coolant in and it is leaking at the lower radiator hose where it connects to the water pump. I tried to tighten the hose but still was leaking I looked closer and there is a timming cover bolt there, does that bolt go into the water jacket. could it be leaking out of that bolt???? If so what kind of sealant should i use? Thanks.
