Joel Chapman
So I traced a leak I was having in my dart to my transmission cooler lines. The previous owner had cut out a section of the line that I assume was leaking in two spots one on each lien and replaced it with rubber line. While I was replacing the lines I noticed that some of the fittings that the flare nuts attach to had Teflon tape on them and some didnt (transmission fittings tape radiator fittings no tape). Do I need to retape all the fittings or use locktite? My repair manual makes no mention of how to properly install these lines. The car is a 71 dart with a 318/904. Thank you in advance for the help!!
