Core Plug Hell..!!!!!
Watts0001
Member
Uk
Hi Guys, any help appriciated.
The core plug in the block behing the engine mount, drivers side has started leaking!!:banghead:
do you think its possible to change this without pulling the motor????
I could probably get the engine mount off by undoing both and lifting the engine slightly.
Has anyone out there achieved this without having double jointed hands, arms, neck etc??????
Or just dump a bottle of RAD WELD in the radiator......thats the mood i.m currently in:angryfir:
PLEASE HELP:prayer:
You may be able to take the mounts off and get at it. I use a chunk of 2x4 and place it under the crank pulley or ballancer.
"They make" or at least "they" usta make expanding, wrench tightened plugs. I've seen 'em rubber, as well as with a cross piece and T - bolt deal. Might "save" until you can get it out.
