cherokeechief79
roughly what do you think it would set me back to have a chassis guy inboard and mini tub the rear of my 68 notch cuda?
I have done 4 cars now and I wouldn't do another for less then $1500 labor
I had mine done for $900. moving the frame rails in, mini tubs, fitting the narrowed dana 60 and doing the sheet metal work. It took a little while but awesome work.
Can't you just find someone to come to your house and do it? if they know what they are doing it could be done in a day.
Agreed. Out here, 1500 would be on the low side to do it and that is with the car stripped! I'm not pulling body/interior panels out of the car at all!
thanks for the input.
the car was a track car so there is no rear seat or rear interior.
I think I will take your advice and try to do most of the work myself and then have someone come over and finish the welding.
the only thing that actually scares me at all is that I think the trunk supports are mounted right where ill be cutting for the wells to be widened.
