been tyring to get all my guages to work in my dash.
first off the gas gauage does not work. I have a test light, and i have power going into the voltage regulator, and power coming out and going to the gas guage. I do not have any power coming out of the gas guage. Does this indicate that the guage is faulty, or is it possible that there is a broken wire between the gas guage and the sending unit?
Second, the dash lights and left turn signal are acting weird. The dash lights can be on, and working. Then they will turn off and the left turn signal light will turn on and stay constant. Wiggling the dash around does effect it and the dash lights and turn signal light will switch around. There does not appear to be any lose wires touching in the wiring harness where it connects to the circuit board.
third, some of the plastic pieces that hold the light bulbs and connect in the circuit board have a plastic clip broken off on one side so they do not connect tightly. Where can i find replacements?
thanks for the help!
