Couple of good weather days here outside of Cleveland, put the 74 sport back on the driveway,this time up on four ramps....Started cutting out the sections of the floor where the water had come in the windows all these years.....Aside from those area this car is solid as the day it was born....Up on the ramps makes is just great for sanding and priming, will remove front and back windows and replace rubber when the spring arrives.....I just have the greatest time working on this as you all probably do also.
