dart_68
Got a couple of questions that I have not seen answered directly.
1) What spark plugs are you using?
2) I'm going to use the Speedmaster head studs. Considering what info ARP provides for their head studs used for the Edelbrock heads,
a) What torque spec are you using (Edelbrock wants 110 gt/lbs)?
b) Are you lubing under the nut/washer and what with?
c) Are you using sealant on the threads and what sealant?
Thanks!
Thanks!
